Warning message
Upgrading to 3DES
I have a PIX firewall (details below) that I am trying to upgrade for 3DES support. When I try to obtain the free upgrade key, I receive a failover only key (PIX TYPE: PIX-515-FO). Am I being stupid, as I only have one firewall and I have not been using failover?
Many thanks
Mark
Firewall Details:
PIX-515, 64 MB RAM, CPU Pentium 200 MHz
Licensed Features:
Failover: Enabled
VPN-DES: Enabled
VPN-3DES-AES: Disabled
Maximum Physical Interfaces: 6
Maximum Interfaces: 10
Cut-through Proxy: Enabled
Guards: Enabled
URL-filtering: Enabled
Inside Hosts: Unlimited
Throughput: Unlimited
IKE peers: Unlimited
This PIX has an Unrestricted (UR) license.
Anonymous (not verified) Fri, 04/30/2004 - 02:30
mark
I have the same problem.I also got a VPN-DES key from the web page I installed it and I downgraded my PIX -UR to FO only and it became unreachable I also had a strange serial number back from cisco the serial number had an extra 44 in front of the original serial number that I typed in. Luckily I had my old key so I copied that back. What did Cisco say ???
Martin
