Warning message
Excluding one port from a signature
Apr 19th, 2004
Gentleman,
I'm trying to Tweak Signature 3030(TCP SYN HOST SWEEPS) to trigger on all ports for the exception of port 80. There is a field Called PortsofInterest but it only allows you to put a single port(set the port to the port you want to trigger on), all ports(set this field to 0), only ports bellow 1024(set this field to 1) and ports above 1023(set this field to 2).
How can I set it so it monitors everything but port 80?
