Warning message
CONSOLE Break
Apr 20th, 2004
I am using a cisco 2500 to access several router consoles using reverse telnet.
Is there a way to send a break sequence to a router console through this connection?
I need to be able to break the boot up on a
remote router.
I am using Windows telnet32 to connect to the cisco 2500.
sstudsdahl Fri, 04/23/2004 - 08:17
  • Silver, 250 points or more
Use the key combination followed by the letter 'B'.
