Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1928983members
1242939discussions
Community Activity
VPN route-based unable to ping remote IP
Hi, I am currently encountering issue on route-based ipsec vpn. I cannot ping my remote IP also the remote tunnel. I have verified that there is no decap showing on packets. I already configured static route between each site and still unsucessful of...
Resolved! Best practice lan configuration
HiI have 4 Cisco 2960 switches and 3 unmanaged switches. All are connected via fiber cable to a core switch 4503-3 and it is connected to a VPN router and internet router. (still don't have access to the routers yet)I know I have to replace the unman...
Service impact on ISE certificate renewal
Hello. I'm trying to renew the ISE's certificate, but I'm using both admin and eap authentication, portal, and radius DTLS. In this case, I would like to know if renewing this certificate will reboot the ISE or if it will cause downtime. The certific...
CCC3 by Level 1
  • 79 Views
  • 4 replies
Site-to-site vpn failover causing memory spike in spoke sites
Hi All. I would like to get your thoughts on the following issue i have been facing since implementing Dual ISP and failover for site-to-site vpn tunnels.Hub Site:ASA5515 using 9.6(4)42Spoke sites:Cisco ISRs using 15.1(4)M8, using voip services over ...
PikaPika by Level 1
  • 67 Views
  • 2 replies
Call Handler Not Reachable From Outside Call
Hi Experts,I am sitting with an unique issue where my Auto Attendant works perfectly from inside the office, however it is not reachable from external calls.Connection ISP > SIP > CUBE > SIP > CUCMWhat I am seeing is as soon as I direct the call to C...
Cisco SD-WAN prefix list & data prefix list update
Wanted to understand the best practices when updating the prefix-list & data prefix list in SD-WAN network.For example I have the below prefix-listlist_abc: 10.10.10.0/24This prefix list has been used in Centralized policy.I wanted to added new subne...
RS19 by Level 4
  • 55 Views
  • 2 replies
Configure Port-channel and vPC in advance in Nexus 9K
hi,i'll be configuring a new N9K switch to replace a C9300.my question is, can i configure in advance the port-channel and vPC in the N9K even without the SFP inserted and fiber cables patched?just want to prepare the config so it will be a faster to...
Resolved! How to do VLAN mapping per Flex Profile on a 9800 WLC
Hi,I have a Flex Connect design on a new 9800 WLC.I would like to know if I can have a different VLAN ID per SSID like the AireOS FlexConnect Group - WLAN VLAN mapping. In my design the Flex Profile is equal to a Branch Office. So I would like to con...
tlarsen by Level 1
  • 3031 Views
  • 10 replies
Resolved! NGFW Sizing
Hi,Please I need an advise to determine the right NGFW based on the below requirements:- Each NGFW physical appliance should provide minimum of 240 Gbps Firewall throughput.- Each NGFW physical appliance must support minimum of 850,000 new TCP connec...
Security Cloud Sign Onの初期セットアップ(Duoインストール版)
はじめに前提条件手順 はじめに 本記事では、Security Cloud Sign Onの設定を初めて行う方を対象に、 Duoの操作画面を参照しながらの初期設定手順を解説する記事となります。 本記事で解説するのはDuoをiOSもしくはAndroidのスマートフォンに運用する場合のセットアップ手順となります。     前提条件 本記事に記載されている内容は2024年4月16日現在のSecurity Cloud Sign Onの動作に基づいて記載しており、将来的に予告なく変更される場合がございます。...
hangga_0-1713919215851.png hangga_1-1713919215857.png hangga_2-1713919215868.png hangga_3-1713919215872.png
hangga by Cisco Employee
  • 19 Views
  • 0 replies
N9K-C9348GC-FXP において、ND ISSU 実施後にカーネルパニックが発生
2024年4月24日 (初版) TAC SR Collection主な問題 Non-disruptive ISSU 実施後、カーネルパニックで筐体の再起動が発生する場合があります。show logging onboard internal reset-reason または show system reset-reason コマンドに、Reset Requested due to Fatal Module Error が出力されます。 `show system reset-reason` ...
