DNS not resolving
May 13th, 2004
I have the following configuration on a CISCO AP 1100
version 12.2
no service pad
service password-encryption
hostname OLS
clock timezone EST -5
clock summer-time EDT recurring
ip subnet-zero
ip name-server 216.162.32.10
ip name-server 216.162.32.20
ip dhcp excluded-address 192.168.100.20 192.168.100.254
ip dhcp excluded-address 192.168.0.1 192.168.100.10
ip dhcp pool ols
network 192.168.100.0 255.255.255.0
lease 10
aaa new-model
aaa group server radius rad_eap
aaa group server radius rad_mac
aaa group server radius rad_acct
aaa group server radius rad_admin
aaa group server tacacs+ tac_admin
aaa group server radius rad_pmip
aaa group server radius dummy
aaa authentication login eap_methods group rad_eap
aaa authentication login mac_methods local
aaa authorization exec default local
aaa authorization ipmobile default group rad_pmip
aaa accounting network acct_methods start-stop group rad_acct
aaa session-id common
bridge irb
interface Dot11Radio0
no ip address
no ip route-cache
ssid OLSWireless
authentication open mac-address mac_methods
speed basic-1.0 basic-2.0 basic-5.5 basic-11.0
rts threshold 2312
station-role root
bridge-group 1
bridge-group 1 subscriber-loop-control
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface FastEthernet0
no ip address
no ip route-cache
duplex auto
speed auto
bridge-group 1
interface BVI1
ip address 192.168.100.149 255.255.255.0
no ip route-cache
ip default-gateway 192.168.100.100
ip http server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag/ivory/1100
radius-server authorization permit missing Service-Type
bridge 1 route ip
banner login This is a private network... Please logoff if you are not a authorized user... Thank you...
line con 0
line vty 5 15
end
As you can see from the configuration, the AP has a user defined dhcp pool, my network does not have a DHCP server at this time.
DNS works from the AP itself. I'm able to ping ip addresses on the wired network and on the wireless side. I can ping domains (www.yahoo.com, www.cnet.com).
However, on the wireless side I can only ping internal ip addresses (192.168.100) either on the wired or wireless part of the network. When I try to surf the internet I get a DNS error. However, if I use the ip address of the website I can connect.
When I do an ipconfig on my laptop, it shows all the ip addresses except the DNS ip address.
Any ideas what I need to do? All assistance is appreciated and thanks in advance
Overall Rating: 5 (1 ratings)
ebreniz Wed, 05/19/2004 - 11:06
  • Silver, 250 points or more
Try using Ap(config)#ip dhcp pool
Include DNS sever name in this so that its propagated to the clients through bootP protocol.
Ap(dhcp-config)#?
DHCP pool configuration commands:
bootfile Boot file name
client-identifier Client identifier
client-name Client name
default-router Default routers
dns-server DNS servers
domain-name Domain name
exit Exit from DHCP pool configuration mode
hardware-address Client hardware address
host Client IP address and mask
import Programatically importing DHCP option parameters
lease Address lease time
netbios-name-server NetBIOS (WINS) name servers
netbios-node-type NetBIOS node type
network Network number and mask
next-server Next server in boot process
no Negate a command or set its defaults
option Raw DHCP options
scuba79 Thu, 05/20/2004 - 05:12
Thanks for the help. I found out about the dns entry after some searching, since the manual does not say anything about it..
