route-map sequence question
Jun 9th, 2004
I have the following configuration:
route-map IPLC_Policy 10
set ip address 101
set ip precedence flash
set interface serial0/1 serial0/0
route-map IPLC_Policy 20
set ip address 103
set ip precedence routine
set interface serial0/0 serial0/1
access-list 101 identifies voice traffic
access-list 103 identifies all traffic
I have this policy applied to the enternet interface on my router. My gloal is to always push all voice traffic over 1 link and regular traffic over the other. Also, if a link should go down, i want to router to know it can then send all traffic over the 1 available link. Will this work?
olorunloba Thu, 06/10/2004 - 02:41
  • Silver, 250 points or more
When the next hop router as specified by the policy routing is not available, the router uses the normal routing table to forward traffic.
Note your configuration should state
match ip address 101
match ip precedence flash
etc rather than the set.
Richard Burts Thu, 06/10/2004 - 09:27
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You are correct that the original posting of the route-map was flawed and should have specified match ip address 101. But the set for ip precedence is correct.
Route maps with multiple set statements are pretty straightforward (it will set several variables) while route maps with multiple match commands get quite complex (it becomes a series of and conditions, and all conditions must be true for the set action to take place).
