Video conferencing through Firewall
We have PIX 515 with Version 6.3(3). We are planning to setup Video conferencing to have a conference with our international customers . We are planning to put the Video conference system behind the firewall for security reasons .I would appreciate if anyone have similar setup and share the Tech aspects like what are the ports to be opened in firewall, fine tuning if any on firewall etc...
Thanks in advance
Raju
shannong Thu, 07/08/2004 - 11:03
  • Silver, 250 points or more
I'll make the assumption you're using H.323?
The fixup support for H.323 is pretty good now and even works with PAT. If you can avoid, don't use PAT for your server. Use NAT with a static statement and you'll have fewer problems.
You should be able to make it work with only opening TCP port 1720. However, this varies from one vendor to another as H.323 is a complicated and varied protocol suite. You may also need to open TCP/389 if you have a Netmeeting/MS based session.
shelton.chan Sat, 07/10/2004 - 18:14
Raju,
You can reference as follow:
Port Range Requirements for TCP and UDP on an iPower
TCP
1700 - 1749
UDP Audio
17000 - 17099
UDP Video
17100 - 17299
UDP Port Control
17300 - 17309
Tip: If a call needs to go through a firewall, be sure to open the configured ports at the firewall as well. In addition to these ports, you must open TCP and UDP ports 1503 for T.120 support and TCP port 1720 for H.225.0 Call Signaling.
And also, you can find more details on polycom web site.
HQABMC2004 Tue, 07/13/2004 - 05:11
