robertcrabbe Thu, 09/30/2004 - 12:44
Is this port supposed to support full duplex? I'm running 8.3(3) and I get an error saying that full duplex isn't supported on this port. When I do a show port capabilites, it says that only half duplex is supported. Is there something I'm missing?
Prashanth Krishnappa Thu, 09/30/2004 - 13:23
  • Cisco Employee,
There is an internal bug for this issue
CSCef54418
Sup720 uplink 5/2 failed to set duplex with 10/100 speed.
Fix will be in 8.4(x) expected during end of October
robertcrabbe Thu, 09/30/2004 - 15:59
Thanks! That's exactly what I was looking for. I appreciate the detailed, fast response.
jbiederstedt Tue, 10/05/2004 - 05:22
I've got two 6509's running 8.3(3) connected via the Sup720 5/2 ports, both set as media type RJ45. One is forced to full/1000, and the other is set to auto/auto. The full/1000 side is running full/1000, and the auto/auto side is running a-full/a-1gb. Showing port capabilities does report each port as only capable of half duplex. Is the 'show port' command incorrectly reporting the ports running at full duplex?
Prashanth Krishnappa Wed, 10/13/2004 - 07:46
  • Cisco Employee,
Thats part of the problem. It can do full duplex but reports it can do half duplex in sh port capabilities.
