self-looping status in spanning tree
Aug 3rd, 2004
hi,
I show spanning tree in cisco 2950 switch and saw
the LBK state. then I viewed the detail and saw self-looping. Did anyone have relevant for LBK or self-looping informaiton.
best regards.
fred.
aashish.c Tue, 08/03/2004 - 21:03
  • Bronze, 100 points or more
LBK state represents Loop-Back state. I would like to know , is it a uplink port or connected to any workstation. also in the logs, are there any messages for loopback state ?
If you have connected balun cable to this port then this can be in LBK mode, balun cable is a loopback cable.
kindly update.
mishao Wed, 08/04/2004 - 01:46
hi,
thanks. we just tested the broadcast-storm in 2950 and 3500XL/2900XL.
2950 blocked the traffic with LBK. but 3500/2900XL hang. So there was different processing for LBK between 2950 and 2900/3500.
best regards.
fred.
Georg Pauwen Tue, 08/03/2004 - 21:14
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 WAN
A self-looping port is usually a port coupled to another port at the same bridge/switch. Can you check if your switch is physically configred like this ?
Georg
