Resolved! Detailed Incoming and Outgoing Calls
Does anyone know of a report that gives the most detailed level of data for incoming and outgoing calls?
The content you are looking for has been archived. View related content below.
We have many Webex Room Kits throughout our institution and are in the process of moving to OS 11.9.3.1. Since moving to OS11, we've needed to disable the On Screen Display (OSD) in order to properly show a wallpaper with instructions for using the s...
Hi, i installed newly cisco codec room kit plus and connected Cisco Navigator pannel but in the network option I am getting an error that "Has not yet received DNS address from DHCP" what is the reason behind this .... ethernet is okay ....what is th...
Hello, reading the datasheet and admin guides of a Roomkit EQ lead us to interpret that it cames with HDMI audio out, but after some tests our technician found that the audio is not working on HDMI outputs, only the embedded QuadCam speakers provides...
Hi Community, I'm looking at designing a space and my question is can you direct the ceiling microphones towards each other or does this cause a problem? i've looked at every design showcasing them on Workspace and online and not once is there two ce...
Hi, we have a configuration with a Cisco Sx80 + Touch 10, 2 cisco P60 cameras, and a Creston 300 with an Android tablet and Creston Go Software.The monitors, Android Tablet, the Creston, are on a switch with a 172.xxx subnet and the cameras and the t...
We have one conference room with a Cisco Room Kit and a Touch10 connected with the MSTeams app on the home screen. The other conference room has an SX80 codec with another Touch10 tablet except this room's tablet does NOT have the Teams app. What is ...
Is the CAB-MIC20-EXT compatible with CS-CODEC-EQ- K9+?
Hey all, we're upgrading some of our conference rooms, and I have some P60 cameras are just getting shoved in a cupboard never to see the light of day again. The optics on these camera's is amazing, so it seems like a waste to me for this to happen. ...
hello all,I recently acquired an old precision 60 camera that was in a container with other broken items. I'm not sure what if anything if wrong with it, but I am trying to see if it works. I do not have the sx80 codec or any other hub for connecti...
HeyAt work we have a Cisco Codec Plus and a Quad camera.We mostly use MS Teams, and then I saw this video online:https://www.youtube.com/watch?v=x5DQLGZ1oBs&t=686sAn admin can enable the function, connect a HDMI to a INOGINI device and audio from the...
Need help with thisVG ALARM TANDBERG: TANDBERG-VG04: HTTP Feedback was unable to post feedback and has stopped\. Thanks,Hariharan Sekar
Main issue: The Webex Room Kit Mini is pulling an IP address, but the TelePresence Touch unit, which is connected to the Room Kit's dedicated Touch port (which I assume acts at least as a pass-through network port) is not (it's getting a 169.254.x.x...
We are experiencing problems with screen sharing when we join a meeting on a Cisco VC device through the MS Teams platform. However, we are able to successfully share our screen using our local device or laptop when joining the same MS Teams meeting ...
Cisco Expressway V. 14.3.4 Select. Where is the setting to disable a user account after X days of inactivity? Thanks
Subject | Author | Posted |
04-14-2024 11:26 PM | ||
04-02-2024 03:18 AM | ||
03-26-2024 08:37 AM | ||
03-22-2024 10:12 AM | ||
03-20-2024 01:51 AM |
