CRA script editor
davidkcampbell
Is the 3.5 CRA editor backward compatible with a 3.1 system? I was told that you need to use the 3.5 editor on a 3.5 system, but I still have many 3.1's I maintain. Thanks in advance ... Dave
venkasub
Level 4
Level 4
The scripts are forward compatible but not backwards.For example:3.0(3a) scripts can be opened in 3.1(2) but 3.1(2) can't be opened in 3.0(3a).
Yes, you need to use the editor that comes along with that CRA system.
Venkat
Thanks Venk :-)
jbid511
Just an FYI, if you open a script after an uograde in CRA, you must convert and save it, then reopen it to ensure it works correctly.
jbid511
And just as FYI, if you open a script after an upgrade to CRA, you must convert and then save that script.
