09-16-2004 03:22 PM - edited 03-02-2019 06:32 PM
hi
howto save Running Config File from CLI by Cisco Router WS-C3550-12T ?
I mean all changes after restart will be saved.
kind regards
p.k.
Solved! Go to Solution.
09-16-2004 04:07 PM
09-16-2004 05:12 PM
Or the much easier old time command "write memory" .
Not sure why they decided to substitute some easier commands like write mem or specially write net for some long convoluted string they want you to use now .
09-17-2004 12:53 AM
It is asking you for a file name in case you want to save the config separately. The default filename is "startup-config", which is the one it will read when it boots. Just hit ENTER.
Kevin Dorrell
Luxembourg
09-16-2004 04:07 PM
The CLI command is
Copy running-config startup-config
09-16-2004 05:12 PM
09-17-2004 12:50 AM
Destination filename [startup-config]?
and how can I find out the name of the startup-config file ?
09-17-2004 12:53 AM
Kevin Dorrell
Luxembourg
09-18-2004 05:27 AM
thanks !
