router doesn't get passed SNMP agent on host is undergoing a cold start
Oct 3rd, 2004
I have a 2503 and a 2501 router that both gets stuck at "SNMP agent on host is undergoing a cold start"
I'v had it running for about 30 minutes no changes, ios is 12.2.
I'm now learing cisco in case some of you are wondering, thanks for your help
Georg Pauwen Sun, 10/03/2004 - 06:07
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 WAN
have any of these routers ever booted properly ? You either have a Flash (hardware) problem or an IOS bug. Can you post the entire boot sequence ?
You could try to install a different IOS version, using the ROMMON recovery procedure, here is the link:
ROMmon Recovery for the Cisco 2500, 3000, AS5100, and uBR900 Series Routers
http://www.cisco.com/en/US/partner/products/hw/routers/ps233/products_tech_note09186a008009464c.shtml
Georg
www.solutionfinders.nl
kimrajsohan Sun, 10/03/2004 - 15:58
Hello Georg
They were all working fine, another collegue of my was using them.
i hope this is what you were looking for:
Cisco Internetwork Operating System Software) 1986-2002 by cisco Systems, Inc.
IOS (tm) 2500 Software (C2500-JS-L), Version 12.2(7), RELEASE SOFTWARE (fc1)
Image text-base: 0x03079490, data-base: 0
Copyright (c) 1986-2002 b
cisco 2500 (68030) processor (revision A) with 16384K/2048K bytes of memory.
Bridging software.
X.25 software, Ve
Processor board ID 01231602, with hardware revision 00000000copyright 1990 by Meridian Technology Corp).
Bridging software.
X.25 software, Version 3.0.0.copyright 1990 by Meridian Te
SuperLAT software (copyright 1990 by Meridian Technology Corp).
Cisco-ET Extended Temperature platform.
TN3270 Emulation software.
1 Ethernet/IEEE 802.3
2 Serial network interface(s)
1 Ethernet/IEEE 802.3 interface(s)s of non-volatile configuration me
16384K
32K bytes of non-volatile configuration memor
Press RETURN to get started!
00:00:09: %LINK-3-UPDOWN: Interface Ethernet0, changed state to uphanged state to down
00:00:09: %LINK-3-UPDOWN: Interface Serial0, changed state to downhanged state to down
00:00:10: %LINK-3-UPDOWN: Interface Serial1, changed state to downn Interface Ethernet0, changed stn
00:00:27: %LINEPROTO-5-UPDOWN: Line protocol on Interface Ethernet0, changed stnine protocol on Interface Serial0, changed statn
00:00:31: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial0, changed statnine protocol on Interface Serial1, changed statn
00:00:32: %LINEPROTO-5-UPDOWN: Line protocol on Interface Serial-CONFIG_I: Configured fr
Compiled Tue 15-Jan-02 20:14 by
Copyright (c) 1986-2002 by cisco Systems, Inc.01:19: %SNMP-5-COLDSTART: SNMP agent on host R
Compiled Tue 15-Jan-02 20:14 by pwade
00:01:19: %SNMP-5-COLDSTART: SNMP agent on host Rack105R2 is undergoing a cold
Here is another message i've noticed after rebooting the router.
Copyright (c) 1986-1995 by cisco Systemsocol on Interface Serial0, changed statn
2500 processor with 16384 Kbytes of main memory
00:00:35: %LIN
Loading cisco2-2500 ... [timed out]erface Serial1, changed statn
File read failed -- Time out
System Bootstrap, Version 5.2(8a), RELEASE SOFTWAREstarted --
Copyright (c) 1986-1995 by cisco SystemsSoftware
2500 processor with 16384 Kbytes of main memory, Version 12.2(7), RELEASE SOFTW
also i was unable to get to your page, i signed in but nothing, bad day for me today
w.iqbal Wed, 12/29/2010 - 01:33
Dear,
I am facing this problem please help out.
*Mar  1 00:00:30.617: %SNMP-5-COLDSTART: SNMP agent on host R1 is undergoing a cold start
After this message router goes on hanged
Faisal
program load complete, entry point: 0x80008000, size: 0x132f0b0
Self decompressing the image : ################################################################################################################################################################################################################################################################################################################ [OK]
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ                 TYPE
00036B          0X00103980 C2611XM Dual Fast Ethernet
                0X00098670 public buffer pools
                0X00211000 public particle pools
TOTAL:          0X003ACFF0
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Rounded IOMEM up to: 4Mb.
Using 3 percent iomem. [4Mb/128Mb]
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
IOS (tm) C2600 Software (C2600-ADVIPSERVICESK9-M), Version 12.3(21), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Mon 06-Nov-06 13:41 by ccai
Image text-base: 0x80008098, data-base: 0x81DDA2A8
A summary of U.S. laws governing Cisco cryptographic products may be found at:
[email protected].
cisco 2611XM (MPC860P) processor (revision 0x100) with 126976K/4096K bytes of memory.
Processor board ID JAD07080P6P (1147248223)
M860 processor: part number 5, mask 2
Bridging software.
2 FastEthernet/IEEE 802.3 interface(s)
32K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
Slot is empty or does not support clock participate
WIC slot is empty or does not support clock participate
interface Serial0/0
% Invalid input detected at '^' marker.
ip address 19.19.125.1 255.255.255.0
encapsulation frame-relay
no fair-queue
frame-relay map ip 19.19.125.2 105 broadcast
frame-relay map ip 19.19.125.5 105 broadcast
no frame-relay inverse-arp
frame-relay lmi-type cisco
interface Serial0/1
ip address 19.19.13.1 255.255.255.0
frame-relay map ip 19.19.13.3 103 broadcast
*Mar  1 00:00:05.897: %LINEPROTO-5-UPDOWN: Line protocol on Interface VoIP-Null0, changed state to up
*Mar  1 00:00:23.045: %LINK-3-UPDOWN: Interface FastEthernet0/0, changed state to up
*Mar  1 00:00:23.045: %LINK-3-UPDOWN: Interface FastEthernet0/1, changed state to up
*Mar  1 00:00:24.291: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Mar  1 00:00:24.291: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/1, changed state to down
*Mar  1 00:00:26.318: %SYS-5-CONFIG_I: Configured from memory by console
*Mar  1 00:00:30.617: %SYS-5-RESTART: System restarted --
[email protected]
