10-14-2004 09:02 AM - edited 03-02-2019 07:16 PM
I have try to set OSPF with Stub Area, after tested, I get ping Lan and Internet IP from PC but
I don't know is it success or not. I have something don't understand.
(1) From OSPF theorem, each router must at lease one interface belongs to area0, othterwise virtual-link is needed,
but from my lab, 1720A seems is not follow the rule, is stub area no need to from virtual-link?
(2) From OSPF theorem, external routes are not propagated inside stub area, stub area router (1720A),
that means when 1720B gerneted default route and propagate to 2620, then it will stop to propagate to 1720A.
But why 1720A now finally can access internet ?
A18 = Area 18, A0=Area0
Pc ->(A18) 1720A (A18) -> (A18) 2620 (A0) ->A(0) 1720B A(0) -> NAT Router(192.168.169.254)
1720A#sh ru
interface Loopback0
ip address 2.2.2.2 255.255.255.0
interface FastEthernet0
ip address 192.168.0.80 255.255.255.0 secondary
ip address 172.0.0.5 255.255.255.252 secondary
ip address 10.0.0.1 255.255.255.0 secondary
ip address 172.0.0.193 255.255.255.192
speed auto
interface Serial0
ip address 172.0.0.2 255.255.255.252
router ospf 20
log-adjacency-changes
area 18 stub
network 10.0.0.0 0.0.0.255 area 18
network 172.0.0.0 0.0.0.3 area 18
network 172.0.0.4 0.0.0.3 area 18
network 172.0.0.192 0.0.0.63 area 18
network 192.168.0.0 0.0.0.255 area 18
ip classless
no ip http server
2620#sh ru
ip subnet-zero
interface Loopback0
ip address 3.3.3.3 255.255.255.0
interface Ethernet0/0
no ip address
ip nat outside
interface Serial0/0
description connect to RouterB
ip address 172.0.0.1 255.255.255.252
ip nat inside
no fair-queue
clockrate 4000000
interface Ethernet0/1
no ip address
interface Serial0/1
description connect to RouterA
ip address 172.0.0.21 255.255.255.252
clockrate 4000000
router ospf 20
area 18 stub
network 172.0.0.20 0.0.0.3 area 0
end
1720B#sh ru
ip subnet-zero
interface Loopback0
ip address 1.1.1.1 255.255.255.255
ip address 192.168.169.252 255.255.255.0
ip nat outside
speed auto
interface Serial0
no ip address
shutdown
interface Serial1
ip address 172.0.0.22 255.255.255.252
ip nat inside
router ospf 20
network 192.168.169.0 0.0.0.255 area 0
default-information originate
ip nat inside source list 1 interface FastEthernet0 overload
ip classless
ip route 0.0.0.0 0.0.0.0 192.168.169.254
no ip http server
access-list 1 permit 192.168.0.0 0.0.0.255
access-list 1 permit 10.0.0.0 0.0.0.255
end
10-14-2004 09:59 AM
I am not sure where you got this:
but it is certainly not true that each router must have at least one interface in area 0. That is only true of ABR (Area Border Router).
2) It is true that in stub areas there is no advertisement of external routes generated from an ASBR. In your example the 1720B generates a default route and advertises it to the 2620 through area 0. The 2620 advertises the default route to 1720B through area 18. The default route is what allows 1720B to access the internet. But there are no external routes in the OSPF table of 1720B.
Rick
10-14-2004 06:57 PM
Yes, you are right,
Pls ignore question 1, I think i know the concept clearly now.
for question 2, is it means that the default route originally is generated by 1720B(ASBR) and propagate to 2620, then 2620 (ABR) will generate another default route AUTOMATICALLY ?
10-14-2004 07:32 PM
The ABR injects a default route as a lsa type 3 in the stub area by default no matter if it has a default route in the RIB or not.
Hope this helps,
10-14-2004 11:19 PM
Thx !
Stub area only receive default route from ABR(2620) type3 LSA but I haven't enter any default route command in 2620 (default-information originate ). That 's why I want to ask is it means after 2620 receive Type5 default route , it will convert to Type3 default route automatically and propagate to Stub area ?
10-15-2004 04:01 AM
The ABR doesn't convert the type 5 lsa into a type 3 lsa.
The ABR doesn't need any special configuration to generate the default route in the stub area. It doesn't need to receive a default route or have a default route installed in the RIB either. It generates the lsa type 3 default route in the stub area by default.
Hope this helps,
