10-22-2004 11:25 AM - edited 03-13-2019 06:46 AM
On a Unity 4.03 sr1, one subscriber has a long delay, 45 seconds, after pressing the 1 to listen to messages. Everything else is normal, logging in, hearing how many messages he has. But when he presses one, it's a long delay. This happens inside the network or outside the network, so the issue is with Unity. This is unified messaging with an off box Exch 2000. This person has subfolders and has about a gig worth of messages. But, another subscriber with 1.4 gigs of messages with subfolders has no problems at all. What could be different with this account than all the others? What can I look for? Thanks.
10-25-2004 01:46 AM
I am also experiencing this and the user's mailbox is only 70mb. Call-Manager 3.3(3) and Unity 4.0(4) - 120 users
Anyone got any ideas on this one?
10-25-2004 03:26 AM
I had a similar problem once when we had restructured our Exchange and Directory Services systems. Try checking that usinty is set up to "talk" to valid Exchange servers, DCs and GCs.
10-25-2004 03:26 AM
10-26-2004 04:27 AM
I had a similar problem once when the Unity server was setup to force the NIC at 100 Full duplex but the port was set to auto detect on the switch. Make sure they're either both auto detect or both forced to 100 full.
Also if you connect to the Exchange server from the Unity server and try and copy a file from one to the other, does it take longer than expected?
10-26-2004 05:17 AM
Thanks for the info, but this only affects one subscriber out of 500.
10-26-2004 06:35 AM
This has been the case in many of our UNITY deployments. Each time a user accesses their voicemail box unity opens up an index with Exchange and parses through the entire inbox of the user. Depending on the size of the users inbox this can introduce minimal to excessive delays. The delay that is being introduced is actually the Exchange server not responding to Unitys request fast enough. This is directly related to the amount of concurrent indexes (indices) that the Exchange server can handle at one time. In order to resolve this problem at another account it required a twofold solution. The first was to move the users Emails to a separate folder and the second, more critical, change was to reconfigure the Exchange server to Microsofts best standard practices which wasnt done originally (i.e., moving log files to separate drive).
