Doing proper NAT to FTP connections on non-standard port
Nov 5th, 2004
Router 1712, IOS 12.3
There is an article from Cisco, "Using Non-Standard FTP Port Numbers with NAT".
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e76.shtml
It explains how to enable NATting router to perform proper translation of NAT-sensitive protocols, in this case FTP.
The article assumes that the FTP server in question is on the inside interface of the router.
The configuration proposed by the article is as follows:
interface Ethernet0
ip address 10.1.1.2 255.255.255.0
ip nat inside
interface Serial0
ip address 192.168.10.1 255.255.255.252
ip nat outside
ip nat service list 10 ftp tcp port 2021
ip nat inside source static 10.1.1.1 20.20.20.1
access-list 10 permit 10.1.1.1
In my case, the FTP server in question is on the outside interface. The router is performing source NAT for outbound connections. An example of my config is below:
interface Ethernet0
ip address 12.34.56.1 255.255.255.0
ip nat outside
interface Vlan324
ip nat inside
ip nat inside source static 10.1.1.100 12.34.56.100
access-list 10 permit 12.34.56.200
With this configuration, Layer 3 NAT is working. I'm able to establish an FTP control channel and issue FTP commands. However, I think that the IP addresses inside FTP control channel are not translated properly (to 12.34.56.100). Therefore, the FTP data channel is not working.
I tried to enable the following debug, however didn't see any entries related to FTP control channel translation:
debug ip nat
debug ip nat detailed
debug ip snat
debug ip snat detailed
debug ip ftp
debug ftpserver
My question is:
Is the "ip nat service list <acl> ftp tcp <port>" command supposed to work when the FTP server in question is on the outside interface of the translating router ?
simon.allen Wed, 02/08/2012 - 07:55
I see that this question was asked quite some time ago but I have come across the same issue, i.e when the server is on the outside interface the ip in the "PORT" command from the client is not translated.
Did you ever get a fix for it?
