Can't reach FTP or TFTP server from CUE
Nov 19th, 2004
Trying to do an upgrade from 1.1.1 to 1.1.2. I'm in boot loader mode and can't ping the FTP or the TFTP servers from the CUE. So, Obviously, I can't run the installer. I've tried all possible gateway addresses and still no luck. I can reach both of them from the CME with no problems, can even transfer files. What am I doing wrong? Am I missing a defalt route somewhere? The servers are on a different segment then the CME/CUE. Thanks.
hinho Fri, 11/19/2004 - 09:20
  • Gold, 750 points or more
Would it be possible for you to install tftp on a laptop and assign it into that segment so u don't have to worry about routing? If that is successful, then you can worry about the routing as a seperate issue.
Search google for "free tftp server download"
d.anthony.hadley_2 Fri, 11/19/2004 - 13:48
Thanks. I was given the wrong address. That was the problem. I appreciate the help.
