RTP relay
Dec 15th, 2004
Is there a Cisco solution to relay/translate between RTP sessions? I will have an application which will handle the signalling itself between VoIP end devices but would like to use a professional equipment to connect the medaia streams transported in RTP.
Gyorgy Kracher
fchaudhr Thu, 12/16/2004 - 04:03
  • Cisco Employee,
Not completely clear on the exact application and the network setup. But have a look at IP-to-IP Gateway, which supports the RTP Flow through mode (besides flow around mode), but IP-to-IP Gateway will be involved in the signaling as well:
http://www.cisco.com/en/US/partner/products/sw/voicesw/ps5640/index.html
Another thing you may look into (depending upon your application) is inserting a Firewall in the middle: PIX will modify the RTP/RTCP port numbers in case you use PAT/NAT and VoIP Signaling will be inspected by PIX and modified in case of NAT/PAT.
