enable portfast on all ports of 2950.
Dec 27th, 2004
Sorry I corrected my question.
Can I enable portfast on all ports of a Catalyst 2950
by one command:
Config#spanning-tree portfast default
or I can only enable portfast on a per port basis.
thanks
Georg Pauwen Mon, 12/27/2004 - 02:51
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 WAN
you can either use the global command 'spanning-tree portfast default', which will put all ports in portfast mode, or the interface command 'spanning-tree portfast' to enable portfast on a specific port.
Further, you can also use the 'interface range' command to configure portfast on a range of interfaces, e.g.:
interface range FastEthernet0/1 - 24
HTH,
GP
Simonwan Mon, 12/27/2004 - 03:09
Hi GP thanks for your help.
For the interface range command.
Should I do it in Config# mode
or should I do it in Config-if# mode
