12-30-2004 03:13 AM - edited 03-02-2019 08:49 PM
eds left a client of mine and their router has an incorrect route i need to remove. i was wondering if someone could walk me through it.
thanks
Host Flags Age Type Address(es)
mi01cubeol (perm, OK) ** IP 200.101.100.1
12-30-2004 03:47 AM
hi,
if it is a static route, then in enable mode type:
conf t
no ip route (the route what you want to remove)
eg.: no ip route 0.0.0.0 0.0.0.0 serial0
12-30-2004 05:36 AM
This is not a route but rather an entry in the host table. you can remove it with the following command in global configuration mode:
no ip host mi01cubeol
Hope this helps,
12-31-2004 01:03 AM
thanks for the reply.
does this entry impact performance at all?
if i remove it, is the configuration automatically saved or do i need to manually save the configuration after i remove it?
12-31-2004 02:15 AM
It should not impact on performance .IP host command will resolve from name to IP in your Router instead of sending to DNS servers for name resolution.I hope you have configured in your Router ip name-server a.b.c.d for name resolution where a.b.c.d is your DNS server IP address. You need to save it after removing /adding any command .
Hope it helps .
Raju
