LOF alarm at the converter
Jan 11th, 2005
Hi all
I was doing an installation for G.703/G.704 to ethernet converter for a radio link. The G.703 interface is provided by the ISP. The ISP uses the Rad FCD-2 modem to configure the bandwidth to 128 kbps. from there it goes to the 3600 router. The converter i m using is AISAi converter.
configuration on my converter is
speed 128 kbps
framing enable
clock slave
and impedance 120ohms
and router configuration is
encapsulation ppp
ppp bridge ip
i m getting a LOF at my side. I try to give loop to the ISP , he gets the loop . If i put conveter in unframed mode my alarm goes and my ethernet comes up but the serial and line protocol of isp goes down. However in both conditions he gets the loop and once the loop is removed i m back to square one.
any help will be appreciated
aasheesh
Overall Rating: 5 (1 ratings)
albert.remo Wed, 01/12/2005 - 01:31
  • Silver, 250 points or more
Hi!
LOF errors are usually caused by mismatches in the configuration. One parameter is the CRC. Try checking the CRC configuration on both the FCD and the router. Try to also look for other mismatches. Just match all the parameters at both end. Surely, when loopback is done, the circuit will work since it sees itself and its own configuration and it isolates itself from the other circuit.
Hope this helps.
Albert
ashish_gupta Wed, 01/12/2005 - 06:47
hi
LOF alarm is gone but the reliability still is low. but thanks for ur help . i beleive the modems dont sync well. by the way do u have idea about G.732N and G.732S signalling. which one goes with G.704
albert.remo Wed, 01/12/2005 - 16:45
Hi!
Glad to be of help. I am not so familiar with those yet but i'll try to do some research. I'll get back to you as soon as I have the information.
Albert
