EIGRP: redistrubuting and default-metric
Jan 20th, 2005
There is something I don't understand in the Cammand Reference :
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fiprrp_r/1rfeigrp.htm#wp1017526.
Under the Usage Guidelines, it says "A default metric is required to redistribute a protocol into IGRP or EIGRP, unless you use the redistribute command." I have looked under the redistribute command, but I cannot see a way to specify an EIGRP metric, only an OSPF one.
http://www.cisco.com/univercd/cc/td/doc/product/software/ios122/122cgcr/fiprrp_r/ind_r/1rfindp2.htm#wp39817
Am I reading the document wrong?
Kevin Dorrell
Luxembourg
thisisshanky Thu, 01/20/2005 - 21:28
Kevin,
Dont you see under the eigrp process -
(say redistributing OSPF to EIGRP)
redistribute ospf 100 metric B D R L M
Kevin Dorrell Fri, 01/21/2005 - 00:17
Thanks. I should have tried it on a lab router; I'll do that next time I have access to one. I was working just from the doc.
In that case it is the doc entry for redistribute that confused me, because it only mentions the keyword metric for OSPF and a single metric, and not redistibution into EIGRP with its multiple metrics. I'll try and check it out for real this evening.
Thanks again.
Kevin Dorrell
Luxembourg
