NTP not getting synchronised
Jan 24th, 2005
Hi these r the command outputs on switch 3560
SWITCH#show ntp associations
address ref clock st when poll reach delay offset disp
~x.x.35.254 0.0.0.0 16 31 64 0 0.0 0.00 16000.
* master (synced), # master (unsynced), + selected, - candidate, ~ configured
SWITCH#show ntp associations detail
x.x.35.254 configured, insane, invalid, unsynced, stratum 16
ref ID 0.0.0.0, time 00000000.00000000 (00:00:00.000 UTC Mon Jan 1 1900)
our mode client, peer mode unspec, our poll intvl 64, peer poll intvl 64
root delay 0.00 msec, root disp 0.00, reach 0, sync dist 0.000
delay 0.00 msec, offset 0.0000 msec, dispersion 16000.00
precision 2**5, version 3
org time C5A067F6.5497BE60 (06:38:46.330 UTC Tue Jan 25 2005)
rcv time C5A067C7.04F724D8 (06:37:59.019 UTC Tue Jan 25 2005)
xmt time C5A067C6.BF60B9B7 (06:37:58.747 UTC Tue Jan 25 2005)
filtdelay = 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
filtoffset = 0.00 0.00 0.00 0.00 0.00 0.00 0.00 0.00
filterror = 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0 16000.0
switch#show ntp status
Clock is unsynchronized, stratum 16, no reference clock
nominal freq is 119.2092 Hz, actual freq is 119.2092 Hz, precision is 2**17
reference time is 00000000.00000000 (00:00:00.000 UTC Mon Jan 1 1900)
clock offset is 0.0000 msec, root delay is 0.00 msec
root dispersion is 0.00 msec, peer dispersion is 0.00 msec
why dont i get the reference clock on show ntp association command?
Martin Ermel Tue, 01/25/2005 - 01:37
  • Blue, 1500 points or more
keep in mind the following:
"NTP avoids synchronizing to a device whose time might not be accurate by never synchronizing to a device that is not synchronized. NTP also compares the time reported by several devices and does not synchronize to a device whose time is significantly different than the others, even if its stratum is lower."
Look at:
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_configuration_guide_chapter09186a0080211321.html#wp1020799
HTH,
Martin
neonetsup Tue, 01/25/2005 - 05:20
Are there any problems with the NTP server the device is pointing to? Do other devices successfully sync to the same server?
