350 PCMCIA: no automatic reauthentication
larsprigge
We use a Cisco 350 PCMCIA for network communication on cranes.
Some cranes lose the network contact to the access point while driving or staying in bad points of a hall, because of a too weak signal and/or signal overlays. This happens about one or two times per week.
If the interruption lasts longer than 5 seconds, the network connection in the systray is deactivated.
When the signal is back in a sufficient strength, there is still no connection to the network (systryicon is disabled; ping does not work). Only if you click in the Aironet Client Monitor on reauthenticate, the connection is up again.
I tried already:
WindowsXP-KB826942 (Windows XP-Supportpatch für Wireless Protected Access)
and Q239924 (disable Media Sense for TCP/IP in Windows)
SP2 seems to solve the problem, but at the moment it is not possible to install ServicePack 2 because of IT Guidelines in the Enterprise.
Is there a possibility to extend the Timeout of 5 seconds ?
Can we automate the reauthentication process?
Can we optimize the clientsettings ?
Details:
Windows XP SP1
current driver version of the Cisco Card
Network Security Settings:
Network Authentication - NONE
DATA Encryption – Static WEP Key
ACCESS POINT Authentication - OPEN
Greetings,
Lars
0 Replies 0
