site to site VPN latency issues
Feb 2nd, 2005
Hello, we'er having slowness issue over our P2P VPN. We hava hub and spoke setup.
Head
PIX 515e
3 spokes
PIX 501's
all are simple IPSEC tunnels with DES encryption. I've checked all connetions for speed/duplex issues, all seem fine. I was wondering about MTU issues. If that's the case, what are my best options to resolve the latency.
The reason I think its an MTU issue is. From one of the spoke sites, I can connect with my XP laptop and browse without much trouble, but 2000 machine are god awfull slow. I checked the MTU of my laptop and it's set to 1300. The 2000 machines are default which I'm assuming is 1500, thus my grand conclusion.
Any help on this is greatly appreciated.
ehirsel Wed, 02/02/2005 - 18:38
  • Silver, 250 points or more
It could be an mtu issue. On the spoke and head-end units, run the show sysopt command and note if any connection tcpmss is not 1380. That is the default value that the pix uses to work properly when it terminates IPSec vpn tunnels.
Is any spoke site connected via PPPoE (or PPPoA in the provider network)? If so, then the effecive interface mtu is 1492, and if you do not allow icmp to and from the pix (note: this is not the same as through the pix) then path mtu discovery is broken. Your XP ws is using an mtu of 1300 so it won't encounter the problem. Either adjust the spoke pix sysopt connection tcpmss to something like 1300, or adjust the interface mtu to 1492.
Let me know what you find.
patgarred Thu, 02/03/2005 - 08:24
Thanks for the reply,
Here's a screen copy of that command. it looks like tcpmss is set to 1380.
privatenetwork# sh sysopt
sysopt security fragguard
no sysopt connection timewait
sysopt connection tcpmss 1380
sysopt connection tcpmss minimum 0
no sysopt nodnsalias inbound
no sysopt nodnsalias outbound
no sysopt radius ignore-secret
no sysopt uauth allow-http-cache
sysopt connection permit-ipsec
no sysopt connection permit-pptp
no sysopt connection permit-l2tp
no sysopt ipsec pl-compatible
no sysopt route dnat
Also, the head site is a 10Mb fibre to Internet and the spokes are T1's one is fractional, so not PPPoE
Thanks for you help.
Patrick
ehirsel Thu, 02/03/2005 - 09:58
Try adjusting the mtu setting on the ms win 2000 client to 1300 for the virtual adapter and then connect. Let me know how it turned out.
patgarred Thu, 02/03/2005 - 10:36
that's fine for testing, except that most of the clients at this site are thin clients (all but 3). WYSE termianls, I was told that you cannot change the MTU setting on them. Also, I don't want to have to change workstation settings. Can't the settings in the PIX be changed to remmedy this?
ehirsel Thu, 02/03/2005 - 12:44
On the pix use this command:
sysopt connection tcpmss x where x can be anything upto 1460; the minimum can be lower than 512 though I do not know the exact value.
Try settting x to 1300 and see if the win 2000 clients can connect. I would make the change on one spoke site first, as that is where the clients reside.
Let me know how it proceeds.
patgarred Thu, 02/03/2005 - 12:50
Thanks for you help ehirsel,
I'll let you know how the test goes when i get a chance to impliment the changes.
