Reporting on Port Bandwidth Usage & Router Utilization
Feb 20th, 2005
I'd like to get monthly port traffic reports on 3 2950's in a cluster. I'd also like to be able to monitor 3 routers in 3 locations for bandwidth utilization.
What is not over the top expensive as there is not a lot of money to be spent?
rameeti00 Mon, 02/21/2005 - 09:29
In hindsight, I don't think I was entirely clear as to what I need. When I said I wanted to know the aggregate amount of bandwidth per port on the Cisco switches, I mean each of the 24 ports on the switches. I don't need to know the usage of port 80, 22, 23, etc. (I sure do wish I knew how to explain this easier. ;-)
steve.busby Mon, 02/21/2005 - 16:49
Your explanation was fine. Look at either of the two products I linked above. They should provide exactly what you're looking for.
Steve
