VPN Failed to establish a secure connection to the security gateway
Answered Question
Feb 20th, 2005
My VPN connection has been working but now after several hours I cannot connect.
My LAN is working. (Windows Server 2003)
The app:
Cisco Systems VPN Client
The error message:
Initiating TCP to 209.189.224.138, port 10000...
Contacting the gateway at 209.189.224.138...
Failed to establish a secure connection to the security gateway.
What could be the problem?
Greg
Correct Answer by sachinraja about 12 years 5 months ago
hey greg,
on the tunnel properties -> transport mode, click ipsec over UDP and try connecting.. I think right now you are connecting through TCP 10000.
Raj
Overall Rating: 3 (1 ratings)
Correct Answer
sachinraja Mon, 02/21/2005 - 03:38
  • Red, 2250 points or more
hey greg,
Raj
