Secure VPN connection terminated by peer. Reason 427 unknown error occured
RobboRobson
Dear All,
I have installed the VPN client on my laptop but everytime i try and connect it authenticates and then errors.
I think it might be an install problem but it keeps happening everytime i reinstall it.
It works fine on any other computers i have.
Any ideas??
The logs are below.
Thanks for the help
James
1 11:35:34.650 02/22/05 Sev=Warning/2 CVPND/0xE3400014
The VPN Client could not find the adapters GUID.
2 11:35:34.650 02/22/05 Sev=Warning/3 CVPND/0xE340000D
The Client was unable to enable the Virtual Adapter because it could not set the IP configuration into the registry.
3 11:35:34.650 02/22/05 Sev=Warning/2 CM/0xE310000A
The virtual adapter failed to enable
4 11:35:34.650 02/22/05 Sev=Warning/2 IKE/0xE3000099
Failed to active IPSec SA: Unable to enable Virtual Adapter (NavigatorQM:936)
5 11:35:34.650 02/22/05 Sev=Warning/
IKE/0xE30000A5
Unexpected SW error occurred while processing Quick Mode negotiator:(Navigator:2202)
wong34539
Level 6
Level 6
If you had loaded any older version of the VPN client try uninstalling them first and then install the VPN client.
There weren't any other versions of the VPN client on my computer when i installed it.
