Cisco Router - NG R55 VPN problem
Mar 1st, 2005
hello,
I have a problem about VPN connection between Checkpoint R55 and Cisco. Configuring an IPSEC Tunnel between a Cisco Router and NG is documented on Document ID 23784.But in this example, both networks inside gateways are private. Unfortunately, I'm trying to make a VPN from NG DMZ Network-172.16.31.0 to reel IP network. And when you debug Cisco, source_proxy is 172.16.31.2, so it is unusable IP in Internet.I see the key exchange from CP to Cisco and from Cisco to CP.
(CP logs are like this: Source:CP Dest:Cisco->IKE: Main Mode completion.Source:Cisco Dest:CP IKE: Quick Mode Received Notification from Peer: no proposal chosen)
And IKE phase 2 is getting unsuccessful. (logs of CP:encryption fail reason: Packet is dropped because there is no valid SA - please refer to solution sk19423 in SecureKnowledge Database for more information) What should I do? Should I make anything on Cisco or CP.
please help!
smalkeric Mon, 03/07/2005 - 08:31
  • Silver, 250 points or more
Check your configurations on both sides agaian, from the error message I guess the Transform set is not matching.
