How to release DHCP IP address
Mar 9th, 2005
I have a DHCP pool created on 2651 router and 3550 switch with VLAN setup. Lease time is 1 day. After connecting devices different times, all the IP addresses are being used. Now, when I connect any device, I can not get any IP address. Is there command I can use to release DHCP addresses?
Georg Pauwen Wed, 03/09/2005 - 14:49
  • Green, 3000 points or more
  • Cisco Designated VIP,
    2017 WAN
try the command:
clear ip dhcp binding
The configurable options are either *, which clears all bindings, or an IP address, which clears the binding for only the specified IP address.
HTH,
GP
