AP350 reset
mbhnt
I need to reset my AP350, and have read that i can use the ":resetall" command - but that isn't an option.
I was upgrading from v12.00T and when it rebooted, i could not connect to it, or ping it. The only way i can connect is via a serail lead. The options i have are:
c -- Copy file
f -- File dir
l -- downLoad file into DRAM
u -- Upload file
p -- xfer Protocol
n -- coNsole
r -- Run
s -- System info.
^Z -- low-level util
U -- Upgrade bootstrap from file
! -- FORMAT memory bank
If i format the memory will it break it beyond repair?
Any ideas? thanks
umedryk
Level 5
Level 5
No, it is not that harmful, but take sufficient backup, date will get erased
