Java applet is being blocked by router firewall
Apr 5th, 2005
We have a Cisco 677 CPE and are trying to connect with MS MeetingPlace software to remote locations. When the software does a Java applet check, it says that the applet is being blocked by the router. We have JVM installed. We would appreciate any suggestions for how to check the router setup for this and how to enable MeetingPlace.
Josef Oduwo Tue, 04/05/2005 - 06:16
  • Gold, 750 points or more
Do you use a proxy? If so, configure JVM to use the proxy, or to use the broswer's (Internet Connection's) settings.
Josef.
SunDevil74 Tue, 04/05/2005 - 06:57
Thanks for your reply.
We are using a VPN to connect to the headquarters network, most often it is a Contivity VPN. We have Alltel ADSL for our broadband provider. Other employees can connect with MS MeetingPlace when they have the same setup but use SBC ADSL with a different router, but we can't make the connection because of this Java applet blockage...
