In ROMMON mode, how to load IOS via TFTP?
Apr 13th, 2005
  • Bronze, 100 points or more
I did a successful Flash memory upgrade on my 2502, but when I tried copying the IOS from my 2501 it didnt' like it. "Wrong system software for this hardware" it keeps saying at bootup. So I send a break signal and get a rommon prompt, and it looks like I can set it up to take an IOS image via TFTP (I'm hoping the one on my other 2502 is good enough); but which commands/arguments do I use at the rommon prompt to make that happen?
Overall Rating: 5 (2 ratings)
mhussein Wed, 04/13/2005 - 14:35
  • Silver, 250 points or more
From the rommon prompt boot into the built-in rx-boot image:
>o/r 0x2101
>i
This should boot the rooter into the bare minimum rx-boot, and from there you can upgrade the image:
router(boot)>enable
router(boot)#copy tftp flash
#continue with the copy procedure, verify file is copied
hostname(boot)#show flash
#reset the config register and reload
hostname(boot)#config t
hostname(boot)(config)#config-register 0x2102
hostname(boot)#reload
See this doc:
http://www.cisco.com/warp/public/130/recovery_c2500.html#download
HTH,
Mustafa
CriscoSystems Wed, 04/13/2005 - 16:31
Thank you; that did the trick.
(except I'm still kinda wondering about those tftp-related commands I saw listed in the 'help" output in rommon mode)
m.gaudion Fri, 04/22/2005 - 08:25
I had to do this today on one of our 2851's.. rommon using the 'set' command and then going through setting up a local ip, and a tftp server ip/image name etc., then using 'tftpdnld' command
The cisco doc linked below was helpful;
http://www.cisco.com/warp/public/471/76.html
Matt
