Metro
Labels
Greetings,I am trying to establish CFM connectivity using emulation (CSR1000v).I am running VPLS (Manual discovery) for end to end connectivity.The topology in use is CE4 - PE2 - PE3 - CE6Connectivity in place , what am not able to get the remote mai...
MTA by Level 1
  • 65 Views
  • 0 replies
Pim{ rp{ static{ address 10.126.1.1{group - ranges{239.0.0.0/24}}}}{Int Fe -0/0/0.0 mode sparse;Version2;}Try to migrate Juniper configuration to Cisco ASR but configuration not working properly
configuration card type 0 4controller e1 0/4/16framing crc4cem- group 0 unframingline code hdb3After this configuration controller still downE1 interface is upWhat will be the issue, anyone suggest ?
Hello   I have server-mapping in network  segment routing in operator  i want tp know if  server-mapping need a License to install  or not ?   I wait a reply from expert segment routing cisco   Thanks in advance
Morning All,New to the forum and had a question regarding adding a module to a 903. Module is a A900-IMA2ZBeen looking around and saw that you can replace a card without powering it down, but can you add a new card to the system without powering it d...
Hi,   I am new to VPLS. I am trying to test VPLS in the lab initially. My set up is extremely basic at present.   CE1 (3560CG-8) ---- PE1 (3850-12XS-S)----PE2 (3850-12XS-S)----CE2 (3560CG-8)   I have followed the instructions on the following Cisco c...
