1200AP fails to aquire IP address, 10.0.0.1 doesn't work
Jun 20th, 2005
I'm having a problem connecting to a 1231 AP. It was working previously, but I reset to factory default to clear the config. Now, it won't pick up an IP address from the DHCP server, and the default address of 10.0.0.1 doesn't work either. I have tried resetting the config again with the mode key, with the same problem.
If I plug a laptop into the Ethernet cable it does get a dhcp lease. The switch it's connected to shows "ap" for show cdp neighbor detail, but no IP address. I tried the IPSU utility, but it doesn't return an address either.
Any ideas on how to reset this?
Thanks, Randy
telnetgj79 Tue, 06/21/2005 - 11:22
Randy,
Try to connect thro' the console port and assign IP to BVI interface on the same subnet as your laptop/PC. I would guess the config might be corrupted.
HTH.
Janakan Rajendran
Randall White Tue, 06/21/2005 - 17:16
I should have mentioned that the console access doesn't work. I can see the boot sequence, but can't enter any commands. I also tried a break sequence, but it looks like Aironet APs don't have a rommon mode.
Randy
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
