Welcome to the Community!
The Community is a hub for connecting with your peers and Cisco specialists to ask for help, share your expertise, build your network, and grow professionally.
New Here? Click here to learn more and get started.
1927858members
1240899discussions
Community Activity
Uccx with sip
I have script with toll free number(sip) the caller sometimes hear all audio prompts in menu, and sometime hear some audio prompts which not stable, but when I dial internally the trigger it is stable and I can hear all audio prompts in menu, What co...
matee by Level 1
  • 209 Views
  • 2 replies
Redistribute routes on ABR router having Area0 and Area 13
Rtr1 ----Cost1-----> Rtr2 (Area13)Rtr1 ----Cost1-----> Rtr3 (Area13)Rtr2 ----Cost10----> Rtr3 (Area10)Rtr2 ----Cost10----> Rtr4 (Area0) If i redistribute static route on Rtr2 then Rtr3 learns best route from Rtr1If i redistribute static route on Rtr4...
Answer phone
I have headset Bluetooth paired with cisco phones and working fine, but auto answer not work. I tried to enable Auto answer with headset on DN but still any incoming call on phone not auto answer, is there anything I miss other than configure auto an...
matee by Level 1
  • 165 Views
  • 5 replies
Secure Firewall / IPS 도입과 활용을 위한 ATXs 세션 다시 보기 모음
안녕하세요.시스코 Customer Success 팀에서 진행한 ATXs(Ask The Experts) 세션 중 Secure Firewall/IPS 관련 세션만 모아~모아~ 공유 드립니다. 세션명진행 날짜 LinkSecure Firewall 스마트 라이선스2023.5LinkSecure Firewall 어플리케이션 탐지 및 URL정책2023.5LinkSecure Firewall Network Discovery 기능 소개2023.5LinkSecure...
Multicast Lab Auto-RP
Hi ALL,I have setup a lab in CML for testing multicast using Auto-RP but I cant see traffic flowing from the source to the receivers . I can see the (S,G) entry in the first hop router and the (*,G) entry in the RP .Appreciate any feedback Thanks,Fra...
Upcoming Event: Capture the Flag, get the Badge!
You asked, we heard you! Introducing the ThousandEyes Support Community Capture the Flag event from April 23rd at 8 AM PST to April 29th at 5 PM PST. This month the ThousandEyes Community is offering two Capture the Flag missions in a single upcoming...
Setting UP a SECOND ASA5506-x firewall
Hello, I successfully set up/configured my first ASA device. I just purchased as second 5506 and am wondering about how compatible or incompatible the bkup configuration files I’ve saved from the first device are gonna be with the second ASA. It ment...
Resolved! Providing certificates for ASA SSL VPN Authentication
I'd like to know if it's possible to give a remote client a certificate that they can import to use for SSL VPN authentication instead of having them generate the request and giving it to us to sign and hand back to them. Using an enrollment server i...
Crag Muer by Level 1
  • 111 Views
  • 2 replies
  • 1 Helpful votes
