If you don't need the "internal" machines to have these new public addresses directly, but can settle for NAT'ing, then it's relatively easy:
interface ATM0
ip address 222.222.222.2 255.255.255.252
ip nat outside
no ip unreachables
interface Ethernet0
ip address 10.10.10.1 255.255.255.0
ip nat inside
! The following route should be you public NAT network
ip route 82.82.82.0 255.255.255.0 Null0
ip nat inside source static 10.10.10.10 82.82.82.10
ip nat inside source static 10.10.10.11 82.82.82.11
This is given that the ISP routes the 82... network to your interface address on the ATM-link..
But if you want the "internal" machines to have the public addresses configured, you could put a secondary address on your internal LAN-if:
NOTE: THIS IS NOT A RECOMMENDED SOLUTION!!
interface ATM0
ip nat outside
no ip unreachables
interface Ethernet0
ip address 82.82.82.1 255.255.255.0 secondary
ip nat inside
Now you can have both internal addresses and public addresses on the LAN.. but... THIS IS NOT A RECOMMENDED SOLUTION!!!
