Warning message
Port-channel bundled/unbundled
Answered Question
Sep 12th, 2005
Is this bundled or not bundled, is what I'm trying to confirm.
I get two conflicting messages about, if the port-channel bundle is working or not working. (There is traffic on two channels intended to bundled)
Version 12.2
Switch1
Config on port 1/1 is encap 820.1q, node (defaul?)
Config on port 9/1 is encap (default?) ,and mode trunk
Switch1 and Switch2 configs are similar
Switch1 extracts
Switch1>sh int po 1 eth
Age of the Port-channel = 01d:04h:02m:05s
Logical slot/port = 14/1 Number of ports = 2
GC = 0x00010001 HotStandBy port = null
Port state = Port-channel Ag-Inuse
Protocol = PAgP
Ports in the Port-channel:
Index Load Port EC state No of bits
0 55 Gi1/1 Desirable-Sl 4
1 AA Gi9/1 Desirable-Sl 4
Time since last port bundled: 01d:03h:45m:47s Gi9/1
Time since last port Un-bundled: 01d:03h:57m:35s Gi9/1
Switch1>sh int g9/1 trunk
Port Mode Encapsulation Status Native vlan
Gi9/1 on 802.1q trunk-inbndl 1
(Po1)
Switch1#sh runn int port-channel 1
Building configuration...
Current configuration : 160 bytes
interface Port-channel1
description EC TO ESW002 G1/1,G9/1
switchport
switchport trunk allowed vlan 200-202,301
end
Switch1#sh run int g1/1
Current configuration : 189 bytes
interface GigabitEthernet1/1
description To ESW002 G1/1
switchport
channel-group 1 mode desirable
end
Switch1#sh run int g9/1
Current configuration : 173 bytes
interface GigabitEthernet9/1
description to ESW002 9/1
switchport
switchport mode trunk
end
Correct Answer by glen.grant about 11 years 11 months ago
You have setup a trunked etherchannel and it appears to be working correctly. this info tells you that the channel is working correctly, to check the trunk do a "show int trunk" also.
Switch1 extracts
Protocol = PAgP
Overall Rating: 4 (1 ratings)
Correct Answer
glen.grant Mon, 09/12/2005 - 15:45
  • Purple, 4500 points or more
Switch1 extracts
Protocol = PAgP
s.srivas Tue, 09/13/2005 - 04:37
Thanks Glen,
Also just noticed
Time since last port bundled: 02d:03h:08m:29s Gi9/1
Time since last port Un-bundled: 02d:03h:20m:16s Gi9/1
unbundled time is larger than bundled time.
glen.grant Tue, 09/13/2005 - 05:40
just means that the last time the etherchannel went down was 02d:03h:20m:16s Gi9/1
Came back up 02d:03h:08m:29s Gi9/1 .
