Warning message
IPSec Tunnel between Cisco 2801 and Netscren 50 with NAT and a static
Answered Question
Sep 12th, 2005
Hello
my problem is not really the IPSec connection between the two devices (it's already running ...) But my problem is that I have a mail-server on the Cisco site, which have a static NAT from inside to outside. Because of the static NAT I can not see the server in the VPN tunnel. I found a document which describes almost the problem:
"Configuring a Router IPSEC Tunnel Private-to-Private Network with NAT and a Static" (Document ID 14144)
NAT takes place before the crypto check !
In that document the solution is "policy routing" by using a loopback interface. But, how can I manage that with the Netscreen firewall. Have anybody an idea ?
thanks for any support
best regards
heiko
Correct Answer by shijogeorge about 11 years 11 months ago
Try modifying your static NAT with a policy based static NAT.
i.e static NAT shouldn't be applicable for the VPN traffic
route-map static permit 1
match ip address 104
access-list 104 deny ip host 10.1.110.10 10.1.0.0 255.255.0.0
access-list 104 permit ip host 10.1.110.10 any
ip nat inside source static 10.1.110.10 81.222.33.90 route-map static
Shijo George.
Overall Rating: 5 (2 ratings)
jackko Mon, 09/12/2005 - 15:57
  • Gold, 750 points or more
create an acl
access-l 100 deny ip
access-l 100 permit ip any
apply the acl above to route-map
route-map test permit 1
match ip address 100
heiko.bachofner Mon, 09/12/2005 - 20:59
hi, thank you for your answer
but I already made the entry in the acl "inside-outside" which I apply to the route-map test (see attachement)
jackko Mon, 09/12/2005 - 21:19
wondering if 10.1.99.20 can access anything from 10.1.110.0/24 but not the .10 mail server, right?
heiko.bachofner Mon, 09/12/2005 - 21:30
yes, thats right
I only can reach the mail-server 10.1.110.10
over its static NAT address 81.222.33.90 not
through the VPN tunnel.
Correct Answer
shijogeorge Tue, 09/13/2005 - 02:29
  • Bronze, 100 points or more
Shijo George.
heiko.bachofner Wed, 09/14/2005 - 06:30
Hi Shijo
thank you very much for your support.
Everything is working fine now.
Your post was very helpfull !
have a good time
best regards
Heiko
