Find out model number of plugged-in SFP
Answered Question
Hi, it seems rather trivial to me but I haven't been able to find any info about it:
Is there a way to determine the model number of an SFP that is in use, via the cli or something similar? I've got several switches which are connected via SFP GBIC's and I would like to know what model or type they are, but since this is in a production environment I can't just go and unplug them to take a look ;)
Thanks in advance!
Correct Answer by Martin Parry about 11 years 11 months ago
If you do a show interface status it should bring up a list of the interfaces, whether they are connected, and will also tell you the media type.
From the media type you can work out the part code.
1000SX - GLC-SX-MM
1000LX/LH - GLC-LH-SM
1000ZX - GLC-ZX-SM
Hope this helps
Overall Rating: 5 (1 ratings)
spremkumar Tue, 09/13/2005 - 19:50
  • Red, 2250 points or more
hi
can you try out with show idprom interface gigabitethernet x/x ??
i use this command in my catalyst boxes to get the serial numbers of those SFPs installed.
regds
Hi, thanks for your answer.
I tried this on a 3560, however on the switch this command doesn't support anything else than a 10-Gigabit Ethernet interface:
http://www.cisco.com/en/US/products/hw/switches/ps5528/products_command_reference_chapter09186a00804761a3.html#wp6007925
IOS comes back with the following output:
ES_SER_18#sh idprom ?
interface Specify an interface for idprom display
ES_SER_18#sh idprom int gigabitethernet0/28
% Invalid input detected at '^' marker.
ES_SER_18#sh idprom gigabitethernet0/28
But although there apparently isn't any way to directly see the exact model number of an SFP, I found what I was looking for by looking at the media type in the 'sh int' command. In my case, it showed '1000BaseSX SFP', which was enough info for me.
Thanks for your help anyways!
Correct Answer
Martin Parry Wed, 09/14/2005 - 01:21
  • Silver, 250 points or more
1000SX - GLC-SX-MM
1000ZX - GLC-ZX-SM
Hope this helps
