Warning message
DMVPN or EzVPN?
Sep 13th, 2005
My goal:
I have 2800 series routers in 4 locations, with 1 acting as the HQ. I also want to provide remote-access VPN to my HQ using the Cisco VPN Client.
Should I use DMVPN because of less configuration, ease of administration?
TIA...
gfullage Tue, 09/13/2005 - 21:57
  • Cisco Employee,
You could use either, personally I'd use EzVPN cause if you set the three remote 2800's up as EzVPN clients, then the HQ router only needs a EzVPN server config and that can then be used by both the 2800 spokes AND the remote access VPN's.
If you use DMVPN you need a separate config for your 2800 spokes and for the remote access setup.
