Warning message
updating an xml file
Sep 13th, 2005
In the push2phone app, i've modified it so that when the alert message is entered users can also enter the details which is in the alertdetail.xml. I'd like to modify the Detail node in alertdetail.xml by passing the text from the form. Can anyone give me a simple javascript coding in a asp file using msxml2.DOM instead of microsoft.DOM?
Even if its creating a new xml file should be ok.
