Warning message
Reset ACS to default - is there a way ?
Answered Question
Sep 14th, 2005
I am about to start some testing on my lab Win ACS 3.3 server and would like to wipe out any previous old config.
Is there a way to do this without re-installing the s-w, ie. just recrate the factory default db's and settings.
I have looked at 'csutil -n' but just seems to be the user accounts.
Any ideas much appreciated ?
Ian.
Correct Answer by andrewclymer about 11 years 11 months ago
Thats unfortunatly correct, a tip for the future is just after installing the product perform a Backup operation. You then have a file you can restore from when ever you need to have a clean config without having to re-install
Overall Rating: 4 (1 ratings)
Correct Answer
andrewclymer Fri, 09/16/2005 - 02:41
