Warning message
QoS manager - QPM
Sep 14th, 2005
After restarting my CiscoWorks server, everything is working great except QoS manager I was able to launch it and start jobs but when I went to view a report it would just give me a red "x". So I restarted the QPM services now I get the following. And the User ID display's unknown
Deployment Groups
QPM Error
Probable cause:
Recommended solution
What did I break?
ivillegas Tue, 09/20/2005 - 13:36
  • Silver, 250 points or more
What is the version of Cisco Works that you are running. I think the QPM in this case has to be reinstalled. Before that we need to make sure if there are any known issues with the version that you are currently having.
b60lselder Tue, 09/20/2005 - 15:10
I got it working after restarting the deamon service. But CiscoWorks Seems to be a bit flakey now.
I have been planning on Upgrading Cisco Works Common Services 2.2 SP 2, to the latest. What would you suggest? QoS Manger Ver. 3.2.
Newbie Lawrence :)
PAUL TRIVINO Tue, 11/01/2005 - 14:17
  • Bronze, 100 points or more
I have my QPM on a separate server (I have CW Solaris but QPM on Windows). But under V3.0.1, I think, I got that error all the time. Since 3.2.1 it's been fine.
