Warning message
CSS + SSL + Oracle Forms
Sep 14th, 2005
Does anyone have any experience with the above combination. I'm terminating SSL sessions on the CSS, the configuration is pretty straight forward, other SSL applications behave normally, and the Oracle forms applications behave normally when http is used, however when going over https, the application becomes very slow. The application is ran using Java Jinitiator on the client side, and the only thing I've noticed is that it appears to be very chatty and creates a new SSL session for each keystroke....
