LAN - ARP Table
Sep 14th, 2005
I'm not sure if someone has come across this before. But they might enlighten me.
Under what circumstances would you see ARP enteries on a switch for subnets out side of the local subnet?
Example 2 switches back to back everything in default vlan 1. These uplink to a pair of routers running HSRP.
I would expect to see x.x.x.200 /24
arp enteries for devices on the switches
but not addresses outside of this range.
Any input appreciated.
Thank you.
lgijssel Wed, 09/14/2005 - 22:24
  • Red, 2250 points or more
Suppose you are talking layer2 switches like the 2950 series?
First of all, this has nothing to do with the switching process on the access ports. The arp table on a switch is only used for the IP management interface. ARP entries will appear for anything that you contact from the console.
Typically anything beyond your local subnet is covered by a default gateway but when the switch is using proxy-arp for address resolution you can see anything on your network.
Leo
