CDP, ping from port
Sep 14th, 2005
Is there a way to log into a 2950 or 3550 and ping certain ports in order to find the IP of the device connected to it? Also how would I find the MAC of the device connected to a specific port?
Josef Oduwo Thu, 09/15/2005 - 01:16
  • Gold, 750 points or more
You can use CDP to find out information about directly connected Cisco devices.
Here is a link on configuring CDP for the 2950 series switches (which generally hold for most access switches)http://www.cisco.com/en/US/products/hw/switches/ps628/products_configuration_guide_chapter09186a00800d84c4.html
For a particular port:
Switch#show cdp interface [type mod/number] so that
Switch#show cdp interface fastethernet 0/3 displays information only about Fastethernet port 3.
Josef.
wrwiii122 Thu, 09/15/2005 - 18:17
But this does not let me see the IP for say a PC connected to the port.
Josef Oduwo Thu, 09/15/2005 - 20:49
No it wouldn't.
To answer your original questions, because switches work at Layer 2 you would only be able to see Layer 2 traffic (MACs) and would not be able to pick up IP addresses of connected devices (Layer 3) by simply logging into a switch. To find the MAC of a device connected to a specific port use the user command:
Switch>show mac address-table interface interface-id [vlan vlan-id] [ | {begin | exclude | include} expression]
More on this command is available here: http://www.cisco.com/en/US/products/hw/switches/ps5528/products_command_reference_chapter09186a00804765f3.html#wp1943113.
You could also use SNMP: http://www.cisco.com/en/US/tech/tk648/tk362/technologies_tech_note09186a00801c9199.shtml#tpic2.
HTH,
Josef.
burhamkri Fri, 09/16/2005 - 02:44
To find the IP address associated with a given MAC address, connect to the router for the subnet that the device is on and run "show arp"
You can speed up the process by only displaying the MAC/IP combo you are looking for with:
"show arp | include [MAC ADDRESS]"
Just make sure you get the mac-address format right.
