Voice Quality Issues and RTP Header Compression
Sep 15th, 2005
Has anyone had problems with RTP Header Compression. A customer is running Voice over IP over our MPLS VPN. They are experiencing packet loss and the interfaces are incrementing flushes and output drops. I have run SAA and seen some SAA packets dropped also. The circuits tested clean so I am beginning to suspected RTP Header Compression. It is enabled on all interfaces and it causes the router to process switch so I am thinking this is creating delays and leads to the flushes and the drops.
Am I on the right path?
Has anyone else seen a problem with RTP Header Compression?
Bruce
teodorgeorgiev Mon, 09/19/2005 - 04:43
  • Bronze, 100 points or more
As far as I remember, Cisco does not recommend running cRTP on links > 768Kbps. As for me, I can say that after 1.2Mbps you can face some peformance issues.
bruce.l.william... Mon, 09/19/2005 - 05:20
I agree. We had cRTP on our T1 interfaces and also on a 30Mbs HSSI interface. I did not want to run cRTP on those links but we had a vendor that insisted. Voice packets were being dropped. There was extensive delay and jitter. We removed cRTP and everything is fine now.
spremkumar Mon, 09/19/2005 - 20:32
  • Red, 2250 points or more
hi
do confirm whether you have got any qos policies defined for different traffic patterns or not ?
and also about the traffic patterns being pumped on that link like the utilisation and the applications being passed on..
regds
