Caller ID??
Sep 16th, 2005
I am trying to block or at least change the caller ID on outbound calls.
I have tried the following:
translation-rule 2
Rule 0 ^. xxx3984028
dial-peer voice 200 voip
preference 1
destination-pattern .T
translate-outgoing calling 2
session target ipv4:10.x.x.2
dtmf-relay cisco-rtp
fax rate 7200
ip qos dscp cs5 media
clid strip
no vad
Neither the clid strip or the translate rule seem to do anything.
My setup looks like this:
PSTN---Gateway---WAN connection--remote router--PBX
The above dial-peers are on the remote router.
Any ideas?
ptredway Fri, 09/16/2005 - 16:12
Dave,
I want to make sure I understand this correctly. You're making calls from your PBX across some kind of TDM circuit to a local router and then across an IP backbone etc etc.
If that's the case, let's first make sure when you place a test call that you are in fact matching this dial-peer.
On the router local to the PBX, turn on 'debug voice ccapi inout' and paste it to this thread.
We'll be able to tell exactly what's going on based upon that output.
vanagon2tdi Mon, 09/19/2005 - 05:32
Changed my translate rule to the below and it worked.
Thanks anyways for your time!
translation-rule 2
Rule 0 any xxx3984028
Cheers!
Dave
