Warning message
Multiple Corporate Directories
Sep 16th, 2005
I am trying to get when a user pushes the Directory button on a 7940/60 option 4 to Say US Directory and also to have an option 5 to say India Directory (instead of Corporate Directory). The option 4 goes to the local Call Manager Cluster while the option 5 goes to the corporate directory that is on a seperate cluster in India.
I am hoping this is posible, but I really have no Idea how to go about it. I am not an XML or ASP scripter by any strech of the imagination but I tried to go in there and Edit the xmldirectory.asp but it does not seem to be working the way I want.
Does anyone have a sample script that I can just put in place of that xmldirectory.asp file and change a few IP addresses and passwords and everything will work fine?
Thanks for any assitance
Ken
Chris Deren Fri, 09/16/2005 - 13:54
  • Hall of Fame,
  • Cisco Designated VIP,
    2017 IP Telephony, Contact Center, Unified Communications
Check out http://www.ccmstuff.org for the corporate directory free service.
Chris
kgroves42 Sun, 09/18/2005 - 18:55
Ah in the SDK there is an ASP file that is called Multidirectory that hopefully does just what I want. It looks like all I have to do is edit the file and replace the xmldirectory.asp file.
kgroves42 Mon, 09/19/2005 - 06:30
Ok that appears to be doing what I want, I now have
ALL Directories Search
US Directory
India Directory
When I select Directory on the phone
I pick one of them I get the
First Name
Last Name
Number
However when I type a name in there I get
HTTP Error [500]!
I have the Call Manager server listed in the DNS and the phones have the DNS server entry.
In the Multidirectory.asp I only edited thes one area where is says "define the directory below" So I added my two Call Manager Clusters there
I used the Directory Manager log on and that password, which I checked by logging into the DC Directory Admin to make sure is works
Any Ideas
aaronw.ca Tue, 09/20/2005 - 04:17
  • Silver, 250 points or more
Did you register the ldapsearch COM component?
You could try that and see if that helps. The component (LDAPSearch.dll) and instructions for registering it (readme.txt) can be found in CiscoIPServices\COMServers\LDAPSearch
If that doesn't work, is there a more specific error, such as "security violation" returned?
Also note that there is a newer version of the IP Phone SDK for CallManager 4.1. That probably won't be an issue for the multidirectory app, but there is a newer version of the ldapsearch COM component. Just FYI.
